Hello
I have a very strange situation with my truck. All was well with it... pulled it out of my garage, went out about an hour later, started it up and pulled it back in. Got up for work the next am, jumped in , and no start , no crank. I noticed the dash voltage gauge was at 0.. Service 4 wheel drive message was lit, along with the abs light. No chimes when i opened the door, no courtesy lights. I put the truck on the charger and let it charge for a day.. Tried to start it.. no change.. no battery voltage showing on gauge. Got new batteries and installed... no change. Cleaned grounds under driver door... no change. Also showing codes for glo plugs.. po671 to 678. I have also learned that half of the fuse block under the hood seems to have no power. Pulled fuse block off and don't see any issue there. When i turn the key to on, the gauges don't sweep.. no courtesy lamps, no turn signals, front windows work but rear windows don't. I haven't gotten a chance to look at it further but plan to today... i'm thinking maybe a wiring harness ? Or Computer issue ? I really have no clue yet... Anyone have any experience with this happening ? I appreciate any insight someone may have .. Thanks in advance.
Lindsay
