Thanks 'Maverick for the tips. Pigtail replacement connector ordered. I noted a couple of YouTube vids on replacing this connector (#7 on one, #4 on another). Looks like the wires are not polarity dependent. ACD #PT3739; GM #19368140 Little over $60 through Amazon. Noted an article that documented 3 common problems with the L5P, one being the #4 injector- but not so much the injector itself, but the connector. Same article stated a connector pigtail for an LBZ would be better, but aren't those injectors Bosch? Wouldn't a connector intended for a Bosch be different from the (Denso), or do they use the same connect interface? Curious to know as the same article referenced both the LB7 pigtails and the gold plated ones.
"Chessy56"
So. Milwaukee, WI
'01 2500HD, LB7, ~440K miles
Winston Churchill
