Thread: Idle surge - dangerous!! What is going on?
    Aug 2000
    Independence, KY, USA
    Default Idle surge - dangerous!! What is going on?
    My 6.5 will on occasion have a sudden surge in the idle speed. So far it hasn't rolled me into the back of another vehicle! I can see the RPM jump up to about 1000 RPM. Generally it will do this twice in very quick succession. Any ideas to check? 94 6.5TD and about 203K miles. I'm the second owner so I'm not sure what has been done as far as major maintenance. Any thoughts? This is concerning and somewhat dangerous. I won't let my boy drive it like this. You have to be on your toes - or more specifically the brake!!
    TIA
    2001 Silverado 2500HD CC Dmax 6spd<br />TST PowerMax<br />Forum #1321 Sold
    1994 GMC Suburban K2500 6.5
    2014 GMC Sierra 2500HD 6.6
    Could be a flaky Fuel Solenoid Driver. Scan it for codes; sometimes they leave evidence behind. Also, if you have a real time scanner, monitor the fuel solenoid closure time (IIRC- it's been over 15 years...)
    Aug 2000
    Is the Fuel Solenoid driver different than the PMD? I have no check engine light, but I'll check for codes.
    Quote Originally Posted by DmaxCC6spd View Post
    No, same thing, but if it's not mounted on the pump than it doesn't make sense to call it a PMD...
    Aug 2000
    Found the following on this site: https://www.accuratediesel.com/pmd_list.html
    If your truck over-responds to the throttle and revs up very rapidly at only light throttle application, or revs up on its own, internal injection pump wear is almost certainly the cause.
    I really don't want to change a pump. Way too busy for that.
  1. Idle Surge
    By shouldaboughtachevy in forum Duramax 6600
    Last Post: 02-12-2010, 21:51
  2. Random Surge at Idle
    By bl78ljb in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-03-2009, 03:33
  3. 01 duramax has slight surge at idle???
    By Vandermax in forum Duramax 6600
    Last Post: 02-04-2006, 11:15
  4. Idle surge and other possible issues...
    By More Power in forum Duramax 6600
    Last Post: 07-13-2004, 09:23
  5. surge @ idle when warm
    By Karl in forum Duramax 6600
    Last Post: 09-14-2002, 18:38
