Originally Posted by
More Power
The first 6.2L diesel I owned was rebuilt because of a collapsed lifter. As a consequence of the rebuild process, I had an opportunity to look at the pistons and rings in this 240,000 mile engine. The oil control rings were quite packed with carbon, and the compression rings were significantly deteriorated due to flaking chrome plating on the faces of the rings.
If on the cheap, this engine could been returned to service with just a good de-carbonization, new rings and new lifters.
After it was rebuilt, I added a new Banks Sidewinder turbocharger system. I then ran this truck for another 40K before it was traded. There was no negative to having the turbocharger - it was a big plus.
Non-turbo 6.2's are pretty dirty, and produce more carbon deposits than a turbo'ed engine. This tends to cake the soot on the pistons and rings unless the engine is used in ways that produce higher combustion temperatures.
The listing of the compression pressures are fairly uniform, though a little low. GM considers 275 psi after 10 puffs on a warm engine as the lowest acceptable. Could be that the pistons just need decarbonized along with fresh rings and new head gaskets. While you're in there, I'd install a new timing chain, and give the heads a good look.
