Results 1 to 2 of 2
Thread: P040B/P041B, EGR circuit
    Jan 2006
    South Milwaukee, WI
    Default P040B/P041B, EGR circuit
    2017 L5P: I've gotten a couple of P040B and P041B (EGR Temp circuit "A" and circuit "B"sensors). No CEL has been set; but the Warm ups w/o Emissions Malfunction counter is reset to "0". I'm having difficulty determining exactly where these sensors are located. I'm making the assumption that these are 2 distinctly located sensors. Since the information I'm seeing on the web doesn't specifically state they are related to the EGR Cooler, I'm thinking somewhere in the exhaust stream before and after the EGR valve itself.
    I'm seeing one sensor that is located between the EGR valve and the intake (after the throttle body) and I believe there is another on the right side (passenger side) manifold (before the "up pipe" to the EGR valve). Am i close in my assumptions and if so, which one is "A" and which is "B"? Or, am I all wrong to begin with?
    Any advice is always appreciated. Thanks!
    "Chessy56"
    So. Milwaukee, WI
    '01 2500HD, LB7, ~440K miles
    Winston Churchill
    Sensor ID is simple. Unplug one before a cold start. Repeat with the other before it warms up. The computer will complain appropriately. Logically, "EGR Temp circuits" would certainly be before, and after the EGR and/or cooler. Other than that, you're probably guessing in the right direction.
  1. Looking for a circuit
    By markelectric in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-03-2014, 18:26
  2. Starter Circuit
    By 84cucv1 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-02-2005, 18:03
  3. Wiper circuit board
    By panhead9 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-26-2004, 16:06
  4. EGR Circuit Error Code 32
    By prichard in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-22-2003, 19:29
  5. EGR Circuit Error Code 32
    By prichard in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 08-22-2003, 18:15
