Results 1 to 5 of 5
Thread: 2007 LBZ Tow Build
    Jul 2020
    Default 2007 LBZ Tow Build
    I thought I should share this build and ask you experienced guys for additional advice in regards to a 2007 LBZ I bought not long ago.
    I fixed a lot of the pre purchase issues it had already. One current issue is a P003 code. I took it to 2 diesel shops and both said the turbo veins are sticking at 78%. They both recommended a new turbo. Sometimes the code/check engine light comes on and then turns off. It runs good overall.
    So with the idea of replacing my turbo, I thought about other things that should get replaced while it is taken apart.
    List of already installed upgrades:
    1.Banks Intake
    Here’s the current list of parts already purchased but not installed yet.
    1. EGR Delete Kit
    2. 5” Diamond Eye Exhaust, No Muffler
    3. 3” Diamond Eye Downpipe
    4. 64MM Fleece Cheetah Turbo
    5. CTS3 Edge Insight
    6. Pillar Mount For The Edge Insight
    Additional items not purchased.
    1. 10 over injectors
    2. Pusher Y Bridge
    3. Pusher Hotside
    4. Pusher Coldside
    5. Pusher Mouthpiece
    6. Upgrade Fuel Pump
    7. Transmission Build up
    8. EFI Live
    9. Motor Brake
    So the goal is to turn it into a better tow rig, get a tad more power and keep reliability.
    What do you experienced Dmax owners think? Other items that should be upgraded or not?
    One of John Kennedy's filter boost pump setups
    How many miles are on the engine? If over 100K, and with the upgrades you're planning, you could consider new head gaskets and ARP studs as a precaution. 2007 was the break-point for the introduction of the newer style riveted head gaskets, which was an improvement over those made earlier.
    Jul 2020
    Filter boost pump? I checked and did not see what you are referring to. Plz share link?
    166,000 at the moment. A shop guy told me the Arp Headstuds could be installed one at a time without removing the heads on a Duramax if it was lower miles. Is this something worth trying to save shop costs at my mileage? How do I tell if it has the newer style head gasket? Just by year?
    https://www.kennedydiesel.com/produc...ry/lly-lbz-lmm
  1. 2007 lbz
    By BBIXLER in forum Duramax 6600
    Last Post: 07-23-2019, 13:49
  2. Eric's 6.5 Tow Build
    By Eric1962 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-03-2018, 15:47
  3. 6.2 Turbo Tow Build
    By richcz28 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-31-2015, 19:20
  4. Tow Mirrors on a NBS 2007
    By tksmitty in forum 2500HD/3500 Accessories
    Last Post: 01-07-2008, 07:54
  5. 2007 LBZ price
    By sb359 in forum Duramax 6600
    Last Post: 06-09-2007, 00:48
