Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Glow plug relay question
  1. #21
    Mar 2020
    Long Beach, CA
    Great, that’s just what I needed to know. If you could point me to where the temp sensor is, that would be extra helpful! Otherwise I’ll start reading up in the books and online. Thanks!
    1995 GMC Suburban C2500
  2. #22
    The PCM temp sensor is in the thermostat housing, and is the only ECT (Engine Coolant Temperature) value the PCM "sees". If this sensor fails, it will mess with the GP cycles and cold start behavior (like timing advance and high idle staying on, or not activating at all). Disconnecting it will "show" the PCM a value of -40°, and a short between the polls will indicate +340°F. A short should trigger the SES and set a code for the sensor. The resistance between the sensor polls can be measured for a linear value of the coolant temp. Very simple test with a VOM (Volt/ohm Meter). I don't recall the range of values, but it should be easy enough to find.
    The temp sensor in the head is for instrumentation only, so disconnecting this will only change what you see on the gauge.
  3. #23
    Mar 2020
    Long Beach, CA
    Great, I’ll check that out. Thanks very much.
  4. #24
    Mar 2020
    Long Beach, CA
    Thanks DmaxMaverick, you saved me. It wasn’t the PCM, as I had a spare that I tried, and it wasn’t the temp sensor, unplugging it didn’t help, I sure hoped it wasn’t the harness, it turned out to be the glow plug relay. I replaced it very recently when I was troubleshooting the initial starting issue, but things went back to normal when I put the old one in just now, which was still working fine. The new one was from Auto Zone, amazing it failed so quickly, what a p.o.s.! Anyway, burb is starting fine and running great again. Thanks!
  5. #25
    That's great! It's always nice when we get stuff figured out.
    I went through something similar on my 2001 Duramax a few months back. There's no difference between the old and new function, but it's more complicated and the parts are a lot more costly. I bought a high-dollar NAPA GP controller, only to find I had a ground issue. I like spare parts, but I'd rather not have $250 parts in the glove box if I can help it. I'd have just bypassed it, but I have to pass a smog inspection every 2 years, and a bypass won't turn off the SES lamp. The Duramax will start w/o plugs down to -8F (tested, albeit rough), but the EPA and CARB isn't happy with it, and they don't trust me with a button.
  6. #26
    Dec 2003
    Yukon Canada
    The EPA might start to have a better disposition...
    Since the their hands got whacked by the supreme court.
  1. Glow plug relay
    By Hooptybass in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-04-2013, 12:32
  2. Glow plug relay ?
    By HudB1 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-01-2003, 06:01
  3. Glow Plug Relay
    By vernj4 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-13-2003, 10:39
  4. Glow plug relay
    Last Post: 10-10-2003, 19:57
  5. Glow plug relay
    By 20050626|2|003738|000000|68.158.211.165 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-28-2003, 09:35
