Thread: Fuel Filter Head In/Out Thread Sizes
    Aug 2019
    Joliet, Illinois
    Default Fuel Filter Head In/Out Thread Sizes
    I'm doing a little plumbing under the hood and I'm trying to find out what size/thread the fuel in/out fittings are on the spin on filter head.
    Also the fittings on the filter on the back of the head.
    Last time I did this kind of thing was on a 7.3 IDI filter head. After a month of trial and error I finally asked on a forum and was informed by EVERYBODY that it was a proprietary fitting that I has to get from International.
    It was one of those things that everybody just knew. Except me.
    So this time I thought I'd forego the month of trial and error and just ask right away. fuel filter.jpgfuel filter.jpg
    1983 Chevrolet C20
    1923ish Ford Model T Touring
    2000 Lincoln Town Car
    I am pretty sure they are NPT fittings.
    I have never come across any propriety fittings on a GM yet
    It's been quite a few years since I've messed with one of those filter assemblies, but if I recall correctly, they are flared fittings (like brake lines), and one size is larger than the other. Sorry, I'm not much more help than that.
  1. Need new fuel filter head- after market???
    By chessy56 in forum Duramax 6600
    Last Post: 02-28-2008, 19:20
  2. Coarse thread head Q's
    By restoguy in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-18-2007, 12:18
  3. Can not find thread on how to change fuel filter
    By outback32 in forum Duramax 6600
    Last Post: 02-22-2007, 14:11
  4. What are the ISSPRO sender thread tap sizes, Please!
    By MTTwister in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-29-2004, 07:44
  5. ERROR - try to post to my fuel filter thread
    By ndamico in forum Duramax 6600
    Last Post: 08-18-2003, 20:06
