Results 1 to 2 of 2
Thread: Emergency brake cables
    Feb 2003
    RAYMOND WA.
    Default Emergency brake cables
    Not sure if this is the proper place for this question'
    when replacing the emergency brake cable because of stretching, which one is more replaced then the others? 2003 2500hd.
    ORDERED 1-15-03 ARRIVED 2-10-03= 03/2500HD/D/A/EXT.CAB LT/ LONG BOX/4X4/CARBON METALLIC/ONSTAR/ TTT CAMPER MIRRORS/WESTIN BOARDS WITH LITES/HUSKY FLOOR LINERS/PRO FIT FLAPS/ACCESS TONNO/LINEX BED RAILS/ FUMOTO OIL DRAIN VALVE,
    BEDRUG/BILSTEIN SHOCKS/ ISSPRO EGT GAUGE/RED LINE LUBE, BANKS EXHAUST BRAKE. GALAXY 929 CB/ WILSON 1000.KENNEDY LIFT PUMP.
    The "cable" is multiple sections. Which section do you suspect has stretched?
    I use my E-brake every day, several times most days, and it's parked, engaged. It's not stretched that I can tell, and I've never had to adjust it. It works the same, and is equally effective, as it was 22 years ago. The cable is "repositioned" to accommodate larger tires, where it passes behind the L/F wheel. I don't know of any GMT-800 E-brake cables that have needed replacement, short of collision or off-road damage. I can't say that for previous model years, and have heard nothing about later years.
  1. Emergency brake light and ABS lights come on
    By kiesurfer805 in forum Duramax 6600
    Last Post: 09-16-2011, 11:03
  2. Emergency: Where'd my Pushrods Go??
    By PeasAndCarrots in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2010, 11:14
  3. 6.2 parts for sale emergency
    By 76m880 in forum TDP Classified ad forum
    Last Post: 07-24-2008, 13:59
  4. 1994 GMC Parking Brake Cables
    By Iain in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 12-15-2006, 11:30
  5. emergency brake locked
    By windjammer in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-20-2002, 03:45
