Thread: LED day light running lights
    Dec 2005
    Klamath falls/keno Oregon
    Default LED day light running lights
    I pulled the oem bulbs out and installed what I thought was a yellow LED bulb, but
    These bulbs aren’t very bright if at all. Is there something I need to add to
    Brighten up the lights?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    LED alternates are fairly straight forward. They work or they don't (other system issues aside), and there's essentially nothing you can do to change their output. DRL lamps aren't supposed to illuminate anything, just be seen. What's the comparable incandescent wattage, lumen, or candlepower rating? Are they both the same?
    Dec 2005
    I’ll pull a bulb and see..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    In my 2001, the DRL lamps ran hot... Hot enough to distort the plastic housing a bit - till the bulbs burned out. I've thought about installing LEDs... Let me if know they work and what the bulb number is... Thx
    Ft. Wayne, In.
    Jim,
    I replaced the sockets and purchased LED DRLs. The socket failure is extremely common. Once I got the sockets replaced and the new bulbs in, I changed the flasher to one made for LEDs. Works awesome. I probably could look up the part numbers if you need them. All parts came from Amazon.
    I agree with Dmax. There isn't any "Brightness Control" for these LEDs.
    d
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
  1. LED lights ?
    By cowboywildbill in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 11-28-2006, 21:31
  2. led lights
    By hug in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 04-01-2005, 09:31
  3. Day Time Running Lights?
    By DA BIG ONE in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-19-2004, 04:57
  4. More LED lights ...........
    By hoot in forum 2500HD/3500 Accessories
    Last Post: 02-05-2003, 18:26
  5. Day time running lights not working???
    By Penngrovian in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 11-09-2002, 15:53
