I pulled the oem bulbs out and installed what I thought was a yellow LED bulb, but
These bulbs aren’t very bright if at all. Is there something I need to add to
Brighten up the lights?
Hummer wheels :^)
dual lift pump
Banks air intake
LED alternates are fairly straight forward. They work or they don't (other system issues aside), and there's essentially nothing you can do to change their output. DRL lamps aren't supposed to illuminate anything, just be seen. What's the comparable incandescent wattage, lumen, or candlepower rating? Are they both the same?
I’ll pull a bulb and see..
Hummer wheels :^)
dual lift pump
Banks air intake
In my 2001, the DRL lamps ran hot... Hot enough to distort the plastic housing a bit - till the bulbs burned out. I've thought about installing LEDs... Let me if know they work and what the bulb number is... Thx
Contact
Feature Articles
Product Reviews
My Photos
Jim,
I replaced the sockets and purchased LED DRLs. The socket failure is extremely common. Once I got the sockets replaced and the new bulbs in, I changed the flasher to one made for LEDs. Works awesome. I probably could look up the part numbers if you need them. All parts came from Amazon.
I agree with Dmax. There isn't any "Brightness Control" for these LEDs.
d
Dave, N9LOV
Member #242
Dave's Diesels:
'97 2 Dr Tahoe, Intercooled,
Kennedy ECM, 4" Exhaust
'02 GMC
