Results 1 to 7 of 7
Thread: Need help identifying 6.5 blocks
    Nov 2022
    Louisiana
    Default Need help identifying 6.5 blocks
    12552929 and 10149599.thanks
    What help do you need?
    you have casting numbers which identify the blocks.A 599 block is the one everyone wants crack free to start with
    The 599 block is a non squirt block (No piston coolers) and has the large outer main bearing bolts
    I have seen these in the 1994 Burbs and pickups.
    A crack free 599 block is a good find.....
    Nov 2022
    Louisiana
    Casting number is.D073
    Nov 2022
    Louisiana
    The 929 is.A265
    The D073 is the date code April 7th 1993 casting date
    "D" January is an A February is a "B" and so on
    "07" Seventh day
    "3" 1993
    The Block being referenced as "929" .....This is the last 3 digits of a 6.5 diesel block....Circa 1993
  1. Identifying my engine
    By AugustDiesel in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-24-2017, 09:31
  2. Help identifying issue
    By jtge in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-26-2014, 08:13
  3. Identifying 506 blocks
    By albcb2 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-05-2007, 19:02
  4. Need help identifying noise!!
    By Barc in forum Duramax 6600
    Last Post: 09-19-2002, 17:04
