12552929 and 10149599.thanks
What help do you need?
you have casting numbers which identify the blocks.A 599 block is the one everyone wants crack free to start with
The 599 block is a non squirt block (No piston coolers) and has the large outer main bearing bolts
I have seen these in the 1994 Burbs and pickups.
A crack free 599 block is a good find.....
Casting number is.D073
The 929 is.A265
The D073 is the date code April 7th 1993 casting date
"D" January is an A February is a "B" and so on
"07" Seventh day
"3" 1993
The Block being referenced as "929" .....This is the last 3 digits of a 6.5 diesel block....Circa 1993
More info on block casting numbers can be found here: https://www.thedieselpageforums.com/...lock-Date-Code
Contact Me
Content Web Site
Photo Album
TDP Youtube Channel - New!
