Originally Posted by
More Power
Personally, I don't worry too much about gelling fuel. I've been driving a GM diesel pickup every winter since 1986. I've never once experienced gelled fuel.
I've been driving GM diesels since 1995. I've gelled up 3 times, all from not using enough fuel treatment during extreme winter cold snaps. I suspect that here in SW MO, we don't have properly winterized fuel since we typically don't have that much extreme cold.
I have an aftermarket fuel filter on my Tahoe, but built my own fuel heater using a 12V heating pad originally meant for RV sewer pipes.
