Results 1 to 6 of 6
Thread: guards for under engine & transmission
    Dec 2005
    Klamath falls/keno Oregon
    Default guards for under engine & transmission
    I cant believe Gm didnt make guards for my 06 3500.
    anyone know of or have a link to after market guards?
    I went into a deep culvets last winter and knocked my
    speedometer cable nutz..
    thoughts?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Get some cardboard and make your patterns then take them to an aluminum welder.
    Just helped a guy with a Frontier who wanted to put some tin ones on to protect his oil pan and diff.I showed him that tin really didn't protect much.
    Those are referred to as skid plates. Looks like your year of truck might be a bit difficult to locate off-the-shelf aftermarket skid plates, but check with 4x4 and off-road clubs and websites to see what is available.
    Dec 2005
    I have all 3 skid plates for a 87 S-10 I had, maybe they might be used,,thanks all.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Speedometer cable?
    Depending on the year and the options many had skid plates from the factory. I would have a look at a friend or neighbor's truck or in a salvage yard.
    Dec 2005
    it wasnt the speedo cable it was the shift linkage at the trans.. my bad
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Need engine harness &/or part number to fit the 1996 K1500 F engine 6.
    By jrsavoie in forum TDP Classified ad forum
    Last Post: 02-27-2014, 13:26
  2. What to do with window rain guards?
    By loghauler in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 06-25-2005, 01:41
  3. GM Molded splash guards
    By Mike Fultz in forum 2500HD/3500 Accessories
    Last Post: 09-11-2003, 11:45
  4. 2003 Grill Guards
    By conradv in forum 2500HD/3500 Accessories
    Last Post: 11-01-2002, 22:19
  5. Bug shield?? Splash Guards??
    By Greg Watkins in forum 2500HD/3500 Accessories
    Last Post: 03-28-2002, 01:00
