Thread: 6.2L Harmonic Balancer replacement - bolt?
    Sep 2000
    California
    Default 6.2L Harmonic Balancer replacement - bolt?
    I'm getting ready to replace my original harmonic balancer with a Fluidampr unit. Is it recommended to replace the harmonic balancer bolt at the same time or can it be used more than once?
    Bob
    '83 K2500, 6.2L J-code, NV4500, NP208, 3.73 gears
    The bolt can be used more than once, and is most often. If yours is original, I would probably replace it, but if it looks good, just as probably reuse it if it's too much hassle. Toss a coin, if necessary.
    Sep 2000
    California
    Sounds good. Thank you.
    Smile 6.2L/6.5L Damper Installer
    I would caution against using the bolt to pull the damper onto the crankshaft. It could strip the threads in the crank snout. Instead, use a crankshaft damper installer like this one, which you can make. You will need a short length of steel pipe to use as a spacer.
  1. Harmonic balancer(s)
    By Carlo in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-14-2015, 15:22
  2. harmonic balancer
    By FredM in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-21-2006, 09:44
  3. Harmonic Balancer
    By coxfmly in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-30-2006, 07:19
  4. Harmonic Balancer washer & bolt
    By stingthieves in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-14-2005, 17:55
  5. Harmonic Balancer
    By BUZZ in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-17-2005, 04:33
