Thread: '94 K2500 keeps blowing 25a front axle engagement actuator fuse(s).
    Jan 2020
    Trabuco Canyon, CA.
    Default '94 K2500 keeps blowing 25a front axle engagement actuator fuse(s).
    Installed new DORMAN 600-100 Actuator (Thermal type) in 2021. Used 4-WD. once or twice since. New fuse blows as soon as key turned "on". Obviously the wiring and or harness or connector(s) or relay(?) etc. may be suspect. I've replaced 3 actuators since 2008 and I'll go a year w/o engaging 4-WD. Any suggestions? Thanks!
    '94 K2500, '82 VW Veggie Cady (sold), Standby: '99 E-350 gasser, Racer: 1964 Front Engine Dragster on E-85.
    Probably a dead short somewhere, or the thermal element itself. Good luck finding it.
    You have alternatives. Update the diff to a modern stepper actuator, or a mechanical push/pull cable. Both are more expensive than replacing the thermal actuator, once.
    I would go with the cable system.
    When you need 4x4 you need it......The Thermal systems are sketchy at best...
    POSILOCK comes to mind.
    This setup replaces the thermal actuator completely..........
    When you engage the front end....It's in.....
    You can also use the low range in the T case as a creeper gear on dry hard surfaces by leaving the front end unlocked.........
    I have had the Thermal actuators fail when I needed it BADLY......Had to lay in the snow and replace it......
    No fun...
    The failure of a Mickey mouse gizmo in a MISSION CRITICAL PART is simply unacceptable.......
    When the weather starts looking sketchy I have always taken the time to try the 4x4 in our GM RIGS to be sure they work....
    Just because it worked the last time you used it....does not mean it will NOW...
    Just my thoughts.......
    As Maverick said....Good luck in finding the issue......Try unplugging the actuator and see if the fuse blows....
    Look over the wiring the feeds the actuator and check for damage down around the axle area.....
    The is also a switch on the T CASE that operates the system.....When the 4x4 is engaged in the case the switch activates the system.
    May be the relay......But as mentioned...Sounds like a dead short.....
    Disconnect the electrical connectors at the axle, then try a new fuse. This'll let you know if it's at the axle or somewhere up the harness.
    As I recall from re-connecting the wiring on the 6.5 Blazer project recently, the front axle wiring passes across the top/back of the engine, sweeps around the back of the passenger side cyl head, then drops down along the starter before leaving the engine toward the axle.
    The point where it sweeps around the back of the passenger side head is a tight spot where I spent some time getting the harness positioned just right, so it was protected.
    Instead of a fuse, stick a test light in the fuse terminals. When you activate the 4WD, if it lights brightly you have short. And, you can re-use the test light as many times as necessary.
  1. Blowing gauge fuse
    By JD4755 in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 10-15-2009, 21:38
  2. ECM-B Fuse blowing
    By stig in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-14-2009, 05:26
  3. ECM1 Fuse Keeps Blowing
    By RobK in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-11-2007, 16:08
  4. Blowing instrument fuse
    By dizzydee in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-30-2005, 02:46
  5. Front drive axle actuator
    By Cooperrw in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-06-2004, 16:14
