Thread: DS4 Phaser Dual-Idler 6.5L Gear Drive Timing Set
    Sep 2012
    Fairbanks, Alaska
    Default DS4 Phaser Dual-Idler 6.5L Gear Drive Timing Set
    Bought when I was installing a P400 in my 95 K3500, but put the Heath cam in the motor which also has built in timing advance... so never installed this gear set.
    https://www.ebay.com/itm/175611980715
    1995 Chevy 3500 Dually 4x4 6.5 Turbo Diesel 4.10 rear end
    P400 Long Block, Heath P400 camshaft, Super Duty cooling upgrade, HD lift pump, Max E Tork tow program, 4" exhaust with 2.5" crossover, Tubro-Master set at 13 lbs boost, Lubrication Specialists oil cooler & SS lines, remote mounted PMD & cooler, SS feed the beast, S&B cold air intake, DIY CAC, Fluidampr, OPS relay, remote dual oil filters, Pyro/Boost/Tranny gauges, Firestone airbags.
    Feb 2012
    Pauline, SC
    I'm a bidder........
    1993 Chevy K3500
    like us on Facebook
    I will not be a bidder then...
  1. Review: Phaser Dual-Idler 6.5L Gear Drive Timing Set
    By More Power in forum Updates & Announcements
    Last Post: 07-28-2014, 14:23
  2. For Sale: Phaser Timing Gear set
    By BuffaloGuy in forum TDP Classified ad forum
    Last Post: 10-20-2008, 05:55
  3. Dual Idler Gear Phaser Kit?
    By j_k_auto in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-09-2007, 23:39
  4. For Sale: 6.5 Dual idler gear set
    By Kevin in forum TDP Classified ad forum
    Last Post: 04-03-2006, 09:47
  5. Dual Idler Gear Timing Set
    By britannic in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-13-2003, 22:04
