Results 1 to 8 of 8
Thread: New tool arrived
    Feb 2012
    Pauline, SC
    Default New tool arrived
    I've waited 3 months for this to be finished, now I have another tool for customer builds and once the 3 builds in progress are run it will be my turn with "Orange Crush" and some projects with it...
    1993 Chevy K3500
    like us on Facebook
    Sweet!
    Yeah buddy.....sweeeeeeeeeeeeeeeeeeeet
    Nice setup you have there. Do you have to hook up the vehicle computer and harness to test run a motor? Or is this for old school motors?
    Feb 2012
    Pauline, SC
    I have a dedicated db2 , If a customer wants to use a ds4 I will swap it once I run the motor. I also don't need all the accessories, I have a electric motor to turn the w/p so it's easy to run a motor.
    1993 Chevy K3500
    like us on Facebook
    Feb 2012
    Pauline, SC
    I'll turn the water pump like this so I don't need any accessories or belt, if the customer want's to use the screw style I'll change it out...
    1993 Chevy K3500
    like us on Facebook
    Is the electric drive for engine dyno testing? I've seen engine shops do that before when they didn't have all of the brackets and pulleys. For actual in-vehicle use, I think an engine-driven setup would be more reliable long-term. Although, for max power to the wheels - like competition, even an engine-driven water pump can reduce that a little - though it takes power to produce the electricity.
    Feb 2012
    Pauline, SC
    Yea, I needed a way to not need all the assories when running motors. Things will be added when in the truck like normal.
    1993 Chevy K3500
    like us on Facebook
  1. Has the grim 6.2L reaper arrived?
    By wfopete in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-07-2006, 17:38
  2. New Engine Just Arrived
    By TimK in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-07-2004, 20:47
  3. 2004 3500 has arrived
    By sonofagun in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 09-25-2003, 09:29
  4. Ok, now what? Dmax intake arrived.
    By Randee of the Redwoods in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-11-2003, 19:23
