Thread: 1999 GMC Suburban K2500 6.5L - Converted to run on straight vegetable oil for sale
    Nov 2023
    Maryland USA
    Default 1999 GMC Suburban K2500 6.5L - Converted to run on straight vegetable oil for sale
    I have a 1999 GMC Suburban K2500 6.2L that is converted to run on straight vegetable oil that I need to get out of my driveway. It's been sitting for a couple of years and needs some work. If it's not inappropriate for this forum, I'm looking to sell it.
    Overall it is in good shape for the age. I stopped driving it when a power steering line burst and it's been sitting since then. Here are the issues it has:
    - Power Steering line needs replaced.
    - a problem in the starter circuit - most of the time it won't crank. The problem is somewhere in the circuit to the Bendix or in the Bendix itself. At the most it needs a new starter. I think it's in the wiring though.
    - a couple of tires have gone flat, and they need to be replaced.
    - It probably needs some glowplugs replaced
    - it needs a good cleaning.
    It ran great on diesel or SVO.
    I had replaced the engine with a junkyard engine that runs fine (The engine seized when an oil cooler line burst). Less than 10,000 miles since I replaced it.
    I've had the transmission replaced with a rebuilt one - less than 5,000 miles on it.
    Replaced the front axel / diff.
    Two fuel tanks - the original steel 44 gallon tank is modified with heat exchangers piped into the coolant lines and I added a 34 gallon tank for diesel.
    Heated SVO filter.
    I'm not looking to make a ton of money on it - make an offer. I can provide details and photos if requested.
    If it's a '99 then it should be a 6.5. Or was that from when you installed the junkyard engine?
    Nov 2023
    Maryland USA
    Typo - It IS a 6.5L Turbo Diesel.
  1. 1999 GMC K2500 6.5 Suburban
    By AKMark in forum TDP Classified ad forum
    Last Post: 02-26-2013, 17:50
  2. 1999 Suburban K2500
    By MJEasly in forum TDP Classified ad forum
    Last Post: 05-29-2006, 20:02
  3. Straight Vegetable Oil as Fuel for DMax
    By FireMedic in forum Duramax 6600
    Last Post: 09-19-2005, 10:21
  4. 1999 K2500 4x4 6.5L TD Suburban FOR SALE
    By Shuck in forum TDP Classified ad forum
    Last Post: 01-30-2005, 11:03
  5. Straight Vegetable Oil conversion
    By jcomp in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-14-2004, 16:56
