Thread: LB7 Trans to engine mounting hardware
    Dec 2023
    USA NC
    Default LB7 Trans to engine mounting hardware
    Finally added viagra to my newly rebuilt Duramax engine and it mated with the Allison!...My question is for anyone who can assist is the bolts to bolt up the trans dipstick tube after installing the 3" PPE down pipe? This engine has been apart since November, finally getting close!. Any images or anything would be helpful. Appreciate any help!
    Generally, all GM engines were assembled as a complete engine. Then, they are mated to the transmission at the vehicle assembly plant. This means, for example, that the transmission dipstick pipe was bolted onto the bellhousing bolts after the transmission was bolted on. GM used bolts that had threads on both ends with the hex in the middle. That bolt allowed the transmission to be bolted on, and then the dipstick pipe added later.
    I tried to get a photo, but even with my bore scope I couldn't see it well enough... Could probably see it from beneath the truck, but... Hope this helps... Jim
    This is likely what will get you taken care of.
    Very commonly used to allow fastening brackets to the rear of the power pack
    https://www.google.com/aclk?sa=l&ai=...BAgGECo&adurl=
    These should be a 10mm IIRC
    Dec 2023
    USA NC
    Default Trans to engine mounting hardware.
    Thanks to Robyn and Jim. Got it done and is mounted in truck, truck is running, but with issues!
  1. What engine and Trans Fluids to use
    By jjcsnlynn in forum Duramax 6600
    Last Post: 12-26-2010, 18:33
  2. 2002 LB7 complete engine,trans,transfer case best offer
    By akers1967 in forum TDP Classified ad forum
    Last Post: 10-30-2010, 22:07
  3. 01 LB7 trans compatability w/ 04.5 LLY truck
    By badburban in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 03-11-2010, 13:16
  4. 82 C10 Engine Mounting Bracket
    By 66stingray in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-11-2009, 09:12
  5. Mounting on home made engine stand
    By nev62 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-19-2006, 22:40
