Results 1 to 2 of 2
Thread: G80 Locker info
    Default G80 Locker info
    While researching why the G80 "Gov-Lok" automatic locking differential is not working in my new SF 14-bolt axle, I came across this awesome video explaining how the locker works. I thought others might find it useful as well:
    https://www.youtube.com/watch?v=ftyJvIO0DZ8
    These lockers are likely one of the best currently on the market....
    They work when you need them and don't cause annoying issues when you don't need them....
    There are a few that are better for rugged off road application.....But for a standard OEM unit....Pretty good...
  1. 9.5" diff /g80 locker swap into 14 bolt 10.5" axle
    By stezloco in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 08-16-2015, 10:44
  2. G80 Locker Functionality
    By k1rod in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-05-2005, 03:04
  3. Hot, smelly G80 Locker??
    By GMC D-Max in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-20-2003, 12:22
  4. Fluid Level for G80 Locker?
    By Dobe Man in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 04-17-2003, 21:10
  5. G80?
    By Swayse in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 11-20-2002, 11:36
