Results 1 to 2 of 2
Thread: Fuel Filter Head Assembly Discontinued - Options
    Sep 2024
    Houston
    Default Fuel Filter Head Assembly Discontinued - Options
    New to the forum so this may be in the wrong place, if so please direct me elsewhere.
    2005 C5500 Kodiak C5U042 Motor Home Cutaway Chassis LLY
    Need to replace the Fuel Filter Head (Housing) Assembly - GM called it Fuel Filter Shell
    OEM Part # is 12645620 but it is long discontinued and none available. Looks like this with the stubby fuel hose attachments.
    All of the available replacements have long curved attachments of different types.
    Anyone been down this road and can tell me the best alternative to use? Any help appreciated.
    Welcome aboard!
    It may be unique to your model, but all pickup versions are still available. They use the same filter cartridge, but may have different in/outlet locations or fittings. Perhaps some creative application engineering may be in order for you. Also, repair kits with seals and some hardware are available, if the problem is simply a leak. Check with aftermarket suppliers like www.kennedydiesel.com for alternatives. If you don't find what you need listed on the site, give them a call.
  1. New fuel filter assembly question.
    By 1984potato in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-19-2007, 08:42
  2. Fuel filter assembly and limp mode
    By KompressorMan in forum Duramax 6600
    Last Post: 04-13-2007, 07:53
  3. Stanadyne Fuel Filter Assembly
    By Mr. Bone in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-25-2007, 12:58
  4. Racor Fuel Filter Assembly Installed With a Twist
    By 56Nomad in forum Duramax 6600
    Last Post: 02-28-2003, 12:33
  5. Fuel Filter Water Assembly Question
    By hjd3021 in forum Duramax 6600
    Last Post: 11-18-2002, 12:55
