Results 1 to 10 of 10
Thread: 2001 LB7 P0102 code
    Dec 2023
    USA NC
    Default 2001 LB7 P0102 code
    Hello to all. Ive come here looking for advice. My truck is a 2001 LB7, it has been down due to head gasket job. Ended up rebuilding the complete engine. Has taken a year!. So got it running Saturday night. Now getting an error code P0102. Had some mods done, cold air intake, high flow up pipes, down pipe, headers, rebuilt turbo (stock), CP3 pump and all the ARP hardware. A friend had his truck down for 2 years but we decided to try his MAF sensor to see if it was a wiring problem or the sensor. His did the same thing. His truck is a few years newer but the sensor appeared the same as mine. Has anyone got a schematic of the wiring for the sensor and what wires do what? I need to diagnose the harness.
    Any help would be MUCH appreciated!
    P0102 - MAF sensor signal is less than the possible range of a normal sensor or less than 16 grams/sec air flow.
    MAF (Mass Air Flow) sensor not properly installed? Unplugged? Broken wire?
    A decent code reader should be able to read the MAF signal. That'll let you know if it's processing a signal.
    I forgot to plug in the MAF in my Lil Red truck following a head gasket replacement. Of course it illuminated the truck's SES lamp. Even after plugging in the sensor, the SES continued to be lit. It took a number of successful key-start-cycles for the SES to remain out. A reader can reset the codes.
    Dec 2023
    USA NC
    The latest, and thanks for the reply. I went ahead and purchased $140.00 Hitachi MAF sensor. Cleared code, installed and drove it and no issue with MAF. BUT! still problem with what I now believe is a transmission communication issue with the engine?
    You get on it, shifts good until you get up to about 40-55 mph and it like it goes into limp mode? Throttle cut in half. Put in neutral and throttle pedal very responsive, full range, no lagging which leads me to believe its a trans communication issue now? And appears to be stuck in a lower gear waiting for a signal to shift up? Does all this make sense?
    Thanks!
    Limp mode can be caused by several conditions, but the trans and throttle behavior will be similar. The SES lamp should be on, and there should be DTC's to indicate what may be the problem, or a direction to a problem system. If one of the codes is P0700 (simply means a TCM request that the PCM light SES lamp), you will need a scanner/reader capable of reading TCM data. TCM communication errors or absence usually cause the PRNDL lamp to flash. Further TCM codes will be stored in the TCM, but most common, inexpensive code readers can't reach them. The same applies to most of the other module codes, which can also cause limp mode and irregular behavior.
    Dec 2023
    USA NC
    Thank you Maverick. You are correct I get no codes on my cheap reader, and when this happens I don't get a check engine light? I have a friend who is bringing a good scanner to see what there is if any.
    If something is amiss with the tranny, it should set the MIL (Malfunction Indicator Lamp, AKA: SES), and P0700. If it isn't shifting correctly, or doesn't seem to, and isn't complaining, something else is not right, and the MIL should be on. About the only thing I can think of at the moment that cold cause poor shifts and/or low power and no DTC's (yet) is fuel contamination or interruption. Low power, such as caused by a plugged fuel filter or contaminated fuel (bio/water/gasoline/air), messes with the throttle position and power correlation, which delays shifts and limits power and RPM under load. If it continues, expect a P--93 code to appear (HP pump unable to produce desired pressure), among other red herrings.
    If it's been down for a year, fuel quality may be suspect, especially if stored outdoors. Diesel fuel doesn't "go bad" like gasoline (I've used 60+ year old fuel in tractor restores with no issues), but can become contaminated, and even grow biological contamination (algae). Water can collect from condensation, compounding the problems, including bio growth. Also, don't rule out mischief, such as someone dumping something into the tank that doesn't belong there.
    Dec 2023
    USA NC
    Default Back again....P0102.
    Well the new MAF sensor didn't do the trick!...Could it be the "cold ait intake" is the problem? Too much air flow? It's an S&B setup, and instructions say there is a plug that can be installed in the bottom of the filter housing if needed?
    They didn't say as to why? I thought better air flow is the key to allowing the engine to breath better!?
    There are 2 areas for air to come into the filter housing, one on the side thru the fender well and a large one on the bottom where the plug would go. Any thoughts please especially after buying a new sensor at $140.00 with no returns.
    Thanks to all your inputs.
    Pat
    Dec 2023
    USA NC
    Ok I may have found the problem GRRRR!...It may be due to the sensor was installed opposite direction!..Yes I'm thinking so. I will test drive and let you all know the results tomorrow. The hole in the plastic is off set to one side as well as the adapter was also offset, so believing that the adapter could only go one way, NOT!..see what happens tomorrow.
    A backward installed MAF would certainly cause issues, and possibly the one you're seeing. I have an aftermarket intake (AFE), and I'm not sure the MAF sensor can be installed wrong, but it never occurred to me, and I never tried it. If you're holding the MAF sensor, flat/label up (sensor stem down) with the connector away from you, the flow should be left to right. Some of the sensors actually have a flow direction arrow on them (not mine, but it's original). It's been a while since I've messed with mine or another similar model, but I don't know if the harness/connector would reach if it were installed wrong (I just checked, and it will reach, barely). However, after an overhaul, there's no knowing how the engine harness is routed, and may be routed or have retainers missing, which may allow it.
    Dec 2023
    USA NC
    And the verdict is in, that was the problem. Now shifting correctly and going thru all gears like it should.
    Thanks to all who have given replies, really appreciate it!...now on to the next problem!
    Will have to start a new thread for this one, and this one is more serious!
  1. P0102 Code
    By bobt in forum Duramax 6600
    Last Post: 08-06-2012, 22:42
  2. 2001 LB7 Headgasket Questions
    By skevac in forum Duramax 6600
    Last Post: 12-09-2010, 08:04
  3. 2001 LB7 fueling problem
    By MPR in forum Duramax 6600
    Last Post: 05-29-2010, 13:14
  4. 2001 LB7 Stalls
    By thebigtoto34 in forum Duramax 6600
    Last Post: 05-04-2010, 14:36
  5. 2001 LB7 Failed Emissions
    By rpaoness in forum Duramax 6600
    Last Post: 07-23-2008, 19:25
