Originally Posted by
scottm
First post since 2013. How have you been getting along without me?
In 2014 I came across a deal on a 94 Blazer 4x4 not running. It has been sitting in my yard untouched ever since. Rats chewed up some wiring and vacuum lines. It is missing some things but I'm not sure what. I have never tried to turn it over with the starter, so I have no idea how healthy it is. It can't be too healthy or it would not have been parked. I'm debating whether to sell it as is or spend possibly months and big $ working on it. It is a rare combination - Wiki says only 4/10s of 1 percent were ordered with the diesel. I have seen them go for over $20k on ebay, or at least they did 3-4 years ago.
So what to do? This weekend I'm going to pull the oil plug and hope there's no water or chunks. Then hook up a battery and spin it. If it has compression then I keep going. I'm just worried about getting all the solenoids and relays and crap hooked back up right. My question is what do you guys think it's worth. 216k miles, paint is typical mid-90s flaking-off white, interior is complete but dry rotting. First year of the electronic Stanadyne injection, OBD1. With this many miles, it is past due for an injection pump and injectors, at the least.
Value:
As is
Barely running and driving
Running and driving well, still needing paint/interior
Scott
As is - $500 to $1500
Barely running and driving - $1500 to $2500
Running and driving well, still needing paint/interior - $4500 to $6500
As a 2 door owner myself, I've watched the market as well. It's coming back down fast. For a while, I couldn't find ANY 2 doors for sale (gas or diesel) for a reasonable price in my area. Now I see a bunch of 2 doors for sale, ranging in price from $1500 to $15,000. They key to the higher priced models is flawless paint and interiors. Even the hard to find diesels don't fetch much more unless the body and interior are immaculate.
Sorry, but I don't think you can make money on this deal. If you want to fix it up for the heck of it, then by all means go for it. You will not be able to fix it up and make a profit... of that I'm sure.
