Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Update on an old Burb.
  1. #21
    It isn't making sense. Seeing is believing, but I'm not seeing. Air has to come from the pump. If the pump is pushing fluid, everything is under pressure, including the return lines when they're returning. The HB unit can't "pull in" air. It can only push excess flow out the return, or to the PS gearbox. If it's foaming, it's coming from the pump, and it takes very little air to make a lot of foam. If there's air in the system, it will exit the HB unit return first. The PS gearbox return is much lower, and it will take much more volume before any air will show there. The pump is pumping air, from somewhere. Most likely a defective pump, with no evidence of a leak, anywhere.
  2. #22
    Jun 2000
    Morrisville, VT, USA
    Okay. Well, then, why doesn't it push foam out the PS return? This is why I posted the question about further testing and possibilities. IIRC (You'd think I'd know,. I was just out there this afternoon!), there's just one pressure line from the pump, which goes to the HB, then the steering gear. So, I think my next step is to lift the car, again, and try the steering, lock to lock a few times. We only tested it , running, today, with wheels on the ground and turning back and forth enough to hear the groaning. I'm inclined to think that I wasn't thorough enough.
    BTW, I already have a rebuilt pump, pump-to-HB hose, filter and fluid, so, I'm set to tackle that end, if I do prove that the pump is bad.
    Thanks for all your good input.
  1. New 89 burb
    By stantjeeper85 in forum Photo Forum
    Last Post: 06-09-2009, 08:05
  2. new 6.5 in my 01 3/4 burb??
    By Vandermax in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-28-2008, 17:22
  3. MPG drop - can't figure out why UPDATE UPDATE UPDATE
    By DennisG01 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-22-2004, 04:15
