Defective injection pump?
Hi all it’s been awhile. I believe I have a remand bad pump on a new engine installation. Got it from QS tuning. Installed the remand pump hard starting, missing, smoke and cylinder balance codes on all 8 cylinders.
https://youtu.be/2aYBAkaTQ_M?si=EdgbYUpEP8R6RO5u
put my original pump back on and it took care of the problems and no codes.
https://youtu.be/jSwnsfMQyUU?si=in5OFlIfXbrblmC7
Both pump installations timing was set within specifications and did nothing different to the engine between pump installations.
The bad thing I bough the remand pump last year and QS tuning said they could check it $500 but it is technically out of warranty. He did say after they check it he might be able to work w/ me. In the mean time I found this bulletin go to the last page sec 5 engine diagnosis. What are you guy’s opinions on this?
thanks guys.
https://www.dieselplace.com/attachme...r2-pdf.380602/
I will have to also change my signature.
1995 k3500 6.5 F TD Dully.OPS hose upgrade (Leroy,s). TM upgrade. VP delete.New complete AC system. K&N open air filter. Diamond 4” turbo back exhaust. 2.5” crossover.New AC delco GP,s. 2/0 upgraded battery cables. Relocated PMD kit(front bumper) from Leroy,s
Leroy,s LP harness. Relocated AC Delco FFM canister w/ stainless braided fuel hoses. High flow water pump and new hoses.[SIGPIC][/SIGPIC]
