Results 1 to 6 of 6
Thread: New here.
    Nov 2024
    Regina Saskatchewan Canada
    Default New here.
    Hello. My name is Peter and I'm a man with a broken diesel. I don't know much about diesels so this is going to be a learning experience for me. So off I go to the 6.5 pages to find help. Thanks for having me and thanks for the forum.
    Pete
    Regina SK CANADA
    1998 Chev 4X4 6.5TD
    Knoxville,Tennessee
    Welcome to TDP
    You have come to the right place
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Welcome!
    You'll find a wealth of info here, and also at the main home page at www.thedieselpage.com
    What all is wrong with your 6.5L?
    Nov 2024
    Welcome!
    Water in the oil. It has been in storage for a number of years. I would like to drop in a new/rebuilt 6.5 engine. I'm just not sure how to go about doing this. My truck engine has 260,000Km.
    Pete
    Dec 2003
    Yukon Canada
    Research your source for a rebuilt engine well, there are a lot of bad re-builders out there
    There are some great options for a good engine, but they cost a few bucks
    I would only trust a brand new AMG GEP Optimizer, such as this:
    https://quadstartuning.com/products/...500-long-block
    There aren't any rebuilders that I trust. They usually cut too many corners.
    The other option would be to rebuild your current engine, depending on what is actually wrong. I would suggest pulling it out and pulling it apart to determine exactly what is wrong, and then make a determination what to do after that.
