Results 1 to 2 of 2
Thread: 6.5TD Project Ideas
    Thumbs up 6.5TD Project Ideas
    I ran across the following image recently while searching the archive for images I need for another video project. The following image was sent to me by member Russ Newton some years ago of his late 1990s (I think 1996) 6.5 Suburban. As I recall, Russ had restored/rebuilt his favorite vehicle... It's beautiful! It's the GM red I like and it has a gray interior.
    I can't help thinking what I would do if I found a Suburban as nice as this one - and it became a new project for The Diesel Page... A couple of ideas...
    1- I think that if I could locate a nice "599" block, another set of small port cylinder heads and a DB2-4911... and many other items, I'd be inclined to build a fuel economy 6.5 powered family cruiser. Maybe install a TH700R4 (it's a little better fuel economy automatic than the 4L80-E, and it wouldn't require a TCM). Maybe 3.42 differential gearing to get the engine RPM at the right speed for max fuel economy. A DB equipped 6.5 would be able to deal with home brewed bio-diesel (or alternative fuels) better than a new DS pump.
    2- Or, put together another Duramax 6600 project, but this one would run a 4L80-E or 4L85-E. The engine would be an L5P (latest gen) but modified to use 2006 LBZ fuel injection (if that's possible). I recently ran across a bunch of info about GM Powertrain's initial testing of the Duramax in GMT-400 trucks using the 4L80-E back in year 1998.
    What do you think? I'll contact Russ, and see what he thinks, and ask him to bring us up to date on his Suburban...
    I have a pretty nice 99 GMC,White with a grey interior
    No rust on the body, paint is so so and it has a few parking lot dings
    I believe that it must of been a shuttle at some point as it has a ton of miles but is in exceptional shape.When i had the engine apart even it looked well taken care off, it had dropped a valve seat and messed up the piston.
    The block had a small crack, but i did not have a crack free block so it was reused with a used piston and used heads.
    Starts and runs great with a Kennedy re-flashed computer
    It is our overlanding road tripper.Building a winch mount on the front is the next project on itsub 4.jpgsub 3.jpg
  1. What year 6.5TD is this? Good engine for my TD project?
    By fullsizeBlazer in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-30-2010, 00:47
  2. anyone have any ideas?
    By 01DURAMAX in forum Duramax 6600
    Last Post: 10-19-2008, 12:15
  3. '94 Burb 6.5TD into '97 K3500 6.5TD Dually?
    By tankertoad in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-13-2008, 21:01
  4. Looking for Ideas
    By convert2diesel in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 07-07-2004, 22:29
  5. 6.5TD Power Project Truck
    By Petrella in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-14-2003, 10:39
