Results 1 to 5 of 5
Thread: 1997 6.5 Suburban with no brake lights
    Jul 2024
    USA, PA
    Default 1997 6.5 Suburban with no brake lights
    Hi, all. The brake lights on my '97 stopped working, but all the other lights work. Before I condemn the switch at the brake pedal, I'd like to check for power out of it at the relay terminals. There's no brake relay in the fuse/relay box under the hood (driver's side), and no female terminals in it to receive a relay anyway, even though the cover diagram says it should be there. Does anyone know where the brake light relay is located? Thanks in advance.
    1997 6.5 K2500 Suburban, stock except for relocated PMD (grill)
    Jul 2024
    USA, PA
    I should have said that the previous owner wired in a TAP Brake Master for towing. I don't know anything about that system.
    Knoxville,Tennessee
    IIRC my 94 had another fuse panel on the left end of the dash. Door open you can remove the cover to access it
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Jul 2024
    USA, PA
    Thanks, a5150nut. The fuse in that block is good. I'm trying to find the square 4-pin relay that, at least on other GMT400s, is in the relay box under the hood.
    Jul 2024
    USA, PA
    It's the switch. I jumpered the orange and white at the switch connector and got brake lights back. I have a vague recollection from years ago, when I replaced the switch before, of losing a really thin metal bushing that slips over the post where the switch sits before you put the switch on. Does anyone know anything about a bushing? I don't mean the retaining clip.
  1. My new to me 1997 Suburban
    By jtge in forum Photo Forum
    Last Post: 03-30-2016, 13:06
  2. Rear Brake Drums keep Warping VIOLENT SHAKE (1997 Suburban 6.5TD)??
    By 97Suburban in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 01-14-2009, 18:00
  3. 1997 Suburban for Sale
    By AKMark in forum TDP Classified ad forum
    Last Post: 08-24-2008, 22:05
  4. service brake system and P brake lights on
    By BBB-Dmax in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 03-06-2007, 06:41
  5. Does the 1997 Suburban have a snorkel?
    By javadog in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-16-2004, 12:05
