Thread: Question on going manual on '84 Glow Controller
    Sep 2000
    California
    Default Question on going manual on '84 Glow Controller
    Had a quick question on adding a manual button to activate the glow plugs on our '84 6.2L. It still has all of the stock '84 controller and relay in place. I want to just abandon the glow controller in the cylinder head and use a manual button. Can I leave everything as-is and then just add a button with one side going to a keyed 12V source and the other side of the button going to the S terminal on the relay? Do I need to run a ground wire from the I terminal on the relay to ground as well? I'm currently running AC Delco 60G glow plugs as well.
    Thanks.
    Bob
    '83 K2500, 6.2L J-code, NV4500, NP208, 3.73 gears
    You can ignore the controller (the temperature inhibit switch). Leave it alone. The relay is just a relay. It doesn't need an additional ground. Apply 12V to the small pole, and it should send power to the plugs, as well as light the GP lamp.
    Sep 2000
    California
    Thank you.
    Bob
  1. Adding a manual button to '85-newer glow controller
    By BobQ in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-21-2023, 21:51
  2. Manual Glow Controller :)
    By Mikeandwendy74 in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 04-13-2015, 16:18
  3. Problems using the electronic glow controller in parallel with manual control
    By argo in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-13-2012, 13:35
  4. 1993 manual glow plug controller
    By granvil96 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-18-2007, 14:19
  5. Glow Controller Question?
    By painthorsman in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-29-2003, 21:46
