Thread: Allison trans issue
    Apr 2018
    Front Royal, VA
    Default Allison trans issue
    Hello All,
    I have a 2003 LB7, on Monday I was driving on the highway at about 72 MPH with the cruise on. Fairly flat area and it felt like the truck downshifted. I looked over at my CTS3 and the rpm's were up a couple of hundred and the gear selection was only showing being in 5th gear. Normally it shows 5 TCL. After a couple of miles the TCL came back on and the torque converter locked back up. The rpm's also came back down. It did this three times during about a 45 mile drive on the highway. The truck has just under 180,000 miles. Trans cooler and lines were replaced last June. Fluid recently checked and all was good at that time. I am a field tech by trade, so the truck is probably over maintained by some standards. Any suggestions would be greatly appreciated.
    EFI Live 0-90 hp tune
    PPE manifolds
    PPE up pipes and down pipe
    Ryan's Diesel 64mm Supercore Turbo
    Banks exhaust and cold air intake
    Banks diff cover
    Mishimoto hot and cold side pipes
    PPE trans cooler and lines
    FASS
    Stock height with Kryptonite upper control arms and ball joints
    2003 Ext. Cab Long Bed
    Banks Cold Air
    Banks Exhaust
    SAC injectors
    EFI Live Tuning
    Apr 2018
    Front Royal, VA
    Could this be a solenoid issue???
    Banks Cold Air
    Banks Exhaust
    SAC injectors
    EFI Live Tuning
    Could it be something simple, like brake pedal return spring allows pedal to sag and hit the brake light switch?
    Apr 2018
    Front Royal, VA
    Thanks JohnC, I will look into it over the weekend.
    I do like your signature.
    Banks Cold Air
    Banks Exhaust
    SAC injectors
    EFI Live Tuning
    Apr 2018
    Front Royal, VA
    The more I think about it, if the brake light switch was being even remotely activated. The cruise control would have disengaged and that did not happen. I now have an Allison service manual from 2000 that shows "Solenoid F" as being the converter clutch solenoid. I recently saw a YouTube video were fluid was leaking into older Allison's solenoids causing issues. Maybe I should just check the external connectors for trans fluid. I don't think it will hurt.
    Banks Cold Air
    Banks Exhaust
    SAC injectors
    EFI Live Tuning
  1. 6.5 turbo auto trans issue
    By wcornell in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-28-2016, 22:17
  2. possible Allison issue
    By LarryMann in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-31-2005, 08:21
  3. Allison Warranty Issue
    By TH in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-29-2004, 08:57
  4. Allison Gear Indicator Issue
    By Eric Alan in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 12-19-2003, 17:20
  5. Allison TCM Reprogram Issue
    By Mike O. in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 07-22-2002, 20:53
