Thread: Best additives for the 6.2 Detroit Diesel Engine?
    Jan 2025
    Midwest
    Default Best additives for the 6.2 Detroit Diesel Engine?
    As the title states, i just recently watched the Project Farm additive v additive video, and im torn between HotShot and Standydne and Howes
    My question to you all is, which additive for lubrication and to prevent gellup do you all use? I've been running Howes lately but I'm not sure, any suggestions would help
    (Project Farm vid: https://youtu.be/J9XC4AJ20RE?t=612&si=KsYnl_EHUN_bF7_p )
    Stanadyne has been the preferred and recommended additive around here since it's made by the folks who built the injection pumps. However, it's kind of like asking which engine oil is the best - as long as it meets the requirements of the engine mfg, then it's okay to use. And you'll find as many opinions as there are additives and oils.
    Personally, I have used Power Service for 30 years now. It's always treated me well. I actually had problems with gelling when using Howes. Anything that you use that adds lubrication and prevents gelling will be fine.
    Aug 2016
    Waco, TX
    Quote Originally Posted by Nycxjeremyy View Post
    I use Bass Pro Synthetic 2 cycle oil for lubrication 10 oz for 25 gal diesel. I would use power service for jelling.
  1. 451 GM detroit diesel engine WANTED
    By 671puller in forum TDP Classified ad forum
    Last Post: 09-06-2018, 19:37
  2. Detroit Diesel 638 engine problem, please help
    By KLUCAFIX in forum General Diesel
    Last Post: 02-23-2018, 22:35
  3. Engine Oil Additives
    By Kent C. in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-28-2004, 13:46
  4. Diesel Additives
    By NewEnglandDmax in forum Diesel Fuel, Bio-Diesel & Fluids Forum
    Last Post: 08-21-2003, 06:28
