Here's another unique option:
https://leroydiesel.com/products/sta...broken-blocks/
However, it's still a bunch of work; you'll have to remove the transmission to install this kit, and then you end up with a unique starter that won't be readily available if you ever need to replace it. But it might be an easier option than pulling the engine and having the block repaired, and is fully DIY.
