Anyone have any experience with the Bosch Glow Plugs? Diesel Injection Service sells the Bosch for $21.60 each vs. the AC Delco Glow Plugs that I can buy for $11.53.
Is there a "Best" Glow Plug I should consider? [img]smile.gif[/img]
1994 Suburban 3/4 ton, 6.5TD (F) 182,560+ miles
You may consider the "quick heat" GP's that Kennedy Diesel sells...http://www.kennedydiesel.com/
$80 for a set of 8.
Cheers
I've got the AC Delco units - AC 60G I believe. Installed at 76k with new injectors, now I have 195k on glow plugs and injectors. I questioned both and was considering installing new until I put in the DSG timing gears and it has started better than new ever since. Even at -10F without being plugged in. The AC units are made by Beru and I think their quality exceeds Bosch.
