Does anyone know where I can find a replacement tank for an 84 Chevy Blazer CUCV? I have a 6.2 and every place I have found so far only have gas tanks not diesel. The filler neck on the Diesel should be much larger.
I have 2 new tanks I bought for a project that I'm not finishing now, let me check filler neck size and I'll let you know what I have.
Sounds great, I will wait to hear back from you.
Thanks
does anyone have any good ideas for a good place to look for a auxillery fuel tank for a 98 short bed chevy, that will fit under a cross over tool box without spending an arm and a leg?
Rob Gregory
01 Chevy 1500 Silverado 2wd 5.3 auto extended cab shortbed pewter w/ billet grill and reprogramer
98 GMC K2500 4x4 Extended cab shortbed 6.5/Nv 4500, 4" straight exhaust, Kennedy boost fooler, 340,000 miles and still tickin on original parts
94 Chevy C2500 Reg Cab long bed 6.5L/NV-4500
85 Chevy K5 Blazer Project, working on acquiring a duramax/allison for the power plant and drive train
actually the gas and diesel tanks are the same size.
The only difference in tanks was I believe around 82-83 when they increased the inlet size, probably diesel related but increased for all tanks regardless of fuel used.
I ran into this when using a 85 box on my 75 frame.
Had to use later model tanks to match hoses from 85 bed, was not a big deal as both 75 tanks were rusted out anyway.
OOOPS just noticed the reference to the military edition, that changes everything as I have no experience with that edition of pickup.
Merle
Rob, Food for thought why not remove spare tire from underneath and use a Tahoe tank clear at the rear of frame?, should fit, locate filler neck in wheel opening.
tank switching could be achieved using OEM dual tank parts.
Merle
hi there,the fuel tanks should be the same.
i've replaced both tanks on my 86 1/2 ton 6.2
and all the parts guys say there is no diffrence
in tank size or filler neck size.
as long as the fuel pump nozzle at the pump is the same as gas.the only place i've seen a larger filler nozzle is at the card locks for the truck stops.with 500L tanks you need to fill them fast
