Thread: Detroit 8.2
    Feb 2003
    Mississippi
    I came across a 1984 brochure for the 8.2It looks very similar to the design of the 6.5 The most interesting part was the dyno sheets. It shows how far Diesel Tech. has come. Base engine non turbo 2 models 145 hp 2800 rpm 330 ft tq at 1200 rpm, and 165 hp at 2800 rpm 345 ft tq 1200rpm.
    Turbo 3 models
    165hp at 2600 rpm 418 ft tq 1400 rpm
    205hp at 2800 rpm 442 ft tq 1700 rpm
    230hp at 2800 rpm 510 ft tq 1700 rpm
    1996 k2500 suburban vin f all stock 246000 miles. I pull a 7400lb 26 ft cabin cruiser.
    Feb 2001
    Collegeville, Pa
    I have driven a few 8.2's in some GMC's mostly tank trucks. It did not compare to the small Cat engines. Ran very well empty, but loaded they were kind of sluggish. It was a short lived engine.
    Roadway Express had some in their C-8000 Ford city tractors, as I think Cat went on a strike back then and Ford needed engines for the C-8000 cab over trucks.
    I don't remember what issues they had, but they had problems, then it was dropped. I always thought it would have been a good swap into a pickup, but the turbo was on the rear center of the engine with a 3"/4" downpipe which would have been a problem at the firewall.
    Thats all I remember as that was in the mid to late 80's . [img]smile.gif[/img]
    Tom McCauley (DP Member #513)
    ace58 Guest
    A local school transportation company had over 200 buses with them in the 80-90s, and they raved about their reliabilty. Of course, loaded they probably didn't equal the tare weight of a city trailer rig.
    john8662 Guest
    From what I've heard about the 8.2 is that it was hard on head gaskets much like the '82 6.2's were. I don't know if this continued to be an issue throughout production though.
    Feb 2003
    Mississippi
    I have never driven one. But from the specs don't you think they were a little under powered? Looks like our 6.5s are moderate contenders.
