I have a small dilemma that I want opinions on, pro and con. First off I have the 97 cooling mods on my 95 K2500 burb. Prior to the install (when I got the burb and didn't know any better) I consulted with a good friend and owner of a local diesel shop about 6.5 cooling. He and I had talked many times about what goes wrong on some of the 6.5's that he had gotten to work on in the shop that had knocks and bad engines. He said that most of them went bad as a result of the #8 cylinder getting too hot and galling. I talked to him many times about what could be done to prevent that from happening. His solution that he had been installing on many early (92-95) 6.5's was a heater hose passage to the passenger side cylinder head. All this consisted of was a piece of 1/2 heater hose, two nipples and a plate for the passenger side head (a plate like whats used on a 6.2 glow controller cigar-style or inhibitor switch). I didn't tow with my 6.5 at the time and didn't really worry about cooling that much so I installed this mod on my 6.5. The plate is installed on the passenger side rear head and gets a nipple installed into it. Then attach the heater hose to the rear of the head and connect it to the extra port on the water pump by installing a nipple in the extra port. It looks like this when installed:
The theory behind the mod (whether it works or not) is that it gives the coolant in the hottest point in a GM head a passage directly do the water pump and to a cooler part of the engine or radiator. This mod in theory (without actually looking at where things flow) could allow this area of the head to cool better and better cool the #8 & # 6 cylinders nearest to the hot turbo system. What direction would coolant really flow in this idea?
Later on I got to reading on TDP about 6.5's, I hadn't paid much attention in the past to anything pertaining to 6.5's as I had a 6.2 at the time and never wanted a 6.5 for all the problems I had heard about them. But since I purchased one (I wanted a TURBO DIESEL) I really have enjoyed it and learning about it, I should have gotten one sooner. From my reading on 6.5's I learned that you could upgrade the cooling system to the "97 cooling mods" by replacing the water pump, thermostats, etc (you've all heard it before.) That
