Results 1 to 20 of 26
Thread: Vacation MPG
    Andy Chesek Guest
    Talking
    Just returned today from a trip to Frisco, NC, in the Outer Banks, and I thought I'd share my MPG info. This is my first long trip since the intercooler was installed. As ugly as it put in, it must work.
    Distance from home to said location was a hair over 450 miles. On the trip down I managed 22.44 mpg. This was maintaining cruising speeds between 62-72 mph, where applicable, but mostly in the 62-67 mph range. Fuel came from my home area Hess station, where I pretty much always fill up.
    On the return trip home I averaged 20.74 mpg. I attribute the lower mileage to a heavier right foot on the way back. Traffic was generally going a bit faster, and I found myself going 78 mph at times. I wouldn't go over 78 because I'm pretty sure my tires aren't rated to go faster... Fuel came from a Mobil station. I don't know what people have to say about chain A versus chain B, but others do like to know who bought what where. Also the first time I ever filled up at a Mobil.
    Anyhow, I was very happy with the fuel economy I experienced during the trip. I borrowed a cap to put over my bed, and literally had the bed stuffed with gear. Couldn't estimate the weight, but sure made the truck ride soft and easy. Too bad we had crummy weather all week, the truck is about the only good thing to talk about.
    Note: In case anyone is wondering if diesel fuel is available in the Outer Banks, the answer is a resounding YES. The majority of stations there do carry diesel, so don't sweat it if you plan on heading down that way.
    Feb 2001
    Collegeville, Pa
    Great MPG's, I assume you have 3:73 Axle ratio . Do you add a cetane booster? You could help with addition cetane. Amoco did have the highest cetane at one time, but since BP joined forces with Amoco who knows. I've been buying at the Flying-J in Carmel Church Va. (I-95, mp#104) about as low a price on the I-95 corridor as can be had. I also do by Hess at time back home.
    A good additive such as FPPF "Total Power" or "Stanadyne" performance forular will help with lubricity and raise cetane levels, plus control waxing in winter, and disperse water.
    I used Stanadyne for years in my 95 suburban, and now use Total Power in my 05 D-Max. [img]smile.gif[/img]
    Tom McCauley (DP Member #513)
    markrinker Guest
    Wow. That is DOUBLE what I would expect to get with either of my 6.5s unloaded. What a (negative) difference 4.10 gears make.
    Andy Chesek Guest
    I did add a little of Power Service's cetane booster (gray bottle, up to +6 points). I try to make sure I add some before I head out on a decent trip, if not more often. I have 3.73's, I didn't mention that in my post because it's in my sig.
    I failed to mention in the earlier post that my previous best was 21.5 mpg, and that was pre-intercooled on a 200 mile trip from Coudersport, PA to Dover, PA. So, if I take the difference between the 22.44 and 21.5 I get 0.94 mpg. That extra 0.94 mpg is a 4.37% increase in fuel economy.
    I guess my truck's a good runner. I like the manual tranny for situations just like this, but it's starting to shutter when I let the clutch out in first or second gear. I replaced the clutch about 28k miles ago, guess it'll need looked at again. As much as people praise manual trannies for being bullet-proof, it seems like they just bite you a little bit at a time but end up costing the same in the end as an automatic... having to replace clutches every 30 - 50k miles.
    Jan 2005
    Plymouth, MN
    My truck is all stock except for a cut out in the air cleaner and a cab height topper. Automatic transmission with 3.73 gears at 78 mph on the freeway I got 18.2 mpg and at 68 mph I got 20.2 mpg. This was about a month ago and with cetane additive to boost 3 numbers. I wish I could do better towing my sleds in the winter. Best I got was 12.4 pulling an open four place (4000 lbs) at 65-68 mph on the freeway and usually averaged about 11.5 mpg. I will see how it does this summer pulling my 5500 lb boat up to Lake Superior. I am hoping for 13 mpg.
    1994 Chevy 6.5TD 1500 Z71 4X4 Extended Cab Short Box Pickup, 3.73 gears & FSD cooler 5W-40 Rotella - I rebuild Snowmobile shocks WWW.shock-service.com
    Lawrenceburg, IN, USA
    Thumbs up
    I'm leaving for Avon, NC this Friday. It's about 760 miles from our home in Indiana. I just installed a Gear Vendor a couple weeks ago. Typically on this trip I'll get just a little over 16mpg. If I run around 75 it will drop under 16. I'm anxious to see what improvement in mileage the GV will give me. However, it won't get much action during the part of the trip through the mountains. (It sure cruzes alot quieter) We usually stay in the Duck area or farther north. I've filled up at the Hess station on the bypass during past vacations. I think they had the best price.
    I usually run Power Service (Grey bottle) But, sometimes I'll stop at the Flying J in Walton, KY to pickup a bottle of "Meaner Cleaner" They did'nt have it today but had something different. "Liquid Muscle" in a gallon jug for $14.95. Must be new cuz the bottle said their trade mark was not registered yet. I'll have to do a search on the internet and see what I can find out. I went ahead and bought a jug. I figured the gallon jug would be perfect for the trip.
    Mike<br />\'99 K2500LT Sub 6.5TD,4:10 grs,8600#gvwr,Praise Dyno brakes,Amsoil Air Fltr,Fumoto Drn Valve,JK\'s Quick Heats,Home Made FSD Clr,LubeSpec oil clr lines, Amsoil bypass,hi idle switch,New Eng 6/02 due to oil clr line failure, Gear Vendor installed
    jspringator Guest
    I don't understand why my mileage is so much worse than everyone else's. The best I have ever gotten was 13.5 and that was a fluke. I usually get around 12.5.I guess I need new injectors.
    Nov 2002
    Australia
    James, don't beat up on yourself. The variables that determine MPG are great.
    My milage ranges from a low of 11.4 mpg to a high
    of 17.4 mpg. The interesting aspect was the 17.4 mpg was obtained last Christmas, while pulling 2 horses and a tub full of camping gear and horse tak. I travel at 60mph with this load, and this doesn't vary much.
    As I said the variables that determine mpg are
    enormous, however the biggest contributing factor in my case has been the gas pedal, hence
    11.4 mpg in and around town.
    Regards; Rod.
    94-GMC-CK, 2500HD,Sierra-4x4 EC,8\'Tub. Removable Nylex Canopy.<br />L65 with 4L80/OD, GT5;4:10 Axels.<br />Conversion LH to RH drive 2000.
    Nov 2002
    Australia
    93_Burrito, The mpg that you listed is brilliant.
    I have a question on the 30-50K miles for clutch replacement, is this typical ?
    The milage sounds a bit low for clutch replacement.
    I am not speaking from experience, I am just curious. I have been running auto's for years.
    Regards; Rod.
    Andy Chesek Guest
    GMCHORSHAM,
    From what I've been reading in numerous threads on this site, there are a few problems that commmonly pop up with manual trannies.
    The first clutch in my truck had several cracks and fragmented pieces. When the mechanic got in there to take a look he said the disc practically crumbled apart on him. This happened with 70k miles on the odometer. I had the clutch replaced with a LuK, and the flywheel was turned down.
    This shutter problem that's developed now seems to be at its worst when the truck has sat overnight. I couldn't take a guess myself to say what the problem may be. With first gear being a granny, I can let the clutch pedal out and it will take off without hitting the accelerator pedal. If I try to let the clutch pedal out slowly, it will shutter almost like a loping feeling. I have about 98k miles on the truck now.
    The first clutch replacement cost over $900, since I don't do bigger jobs like that myself. So, if I have another situation brewing like that and it were to cost me another $900, compare that to an automatic tranny rebuild... adds up pretty quick and to me an automatic is starting to look pretty good given I've got let than 30k miles on the new clutch.
    The 4L80E transmission serves many DP members well, so I wouldn't mind having a truck equipped with one. I'll probably sell this truck to get an automatic. Takes care of another issue as well, my vertically challenged girlfriend has trouble reaching all the pedals in my truck so she refuses to drive it.
    moondoggie Guest
    Good Day!
    James Springate: I can only parrot what I
    Andy Chesek Guest
    I'm running LT245/75/R16 BFG All-Terrain AT/KO's, which is the same tire size it came with from factory.
    jspringator Guest
    I have stock tires, TDC offset of -1.5. I see about 8 MPG while towing a 33 foot travel trailer. 12.5 is every day driving, around town and 15 mile trips. The PO told me he got 15, but I have never been near that.
    Apr 2003
    Salem, Ohio
    I have a 30' Jayco fifth wheel that is pretty tall(11') and catches alot of wind. I get right at 12 mpg pulling it, doing 65 mph.
    I just took a trip to michigan pulling my 16' flat bed trailer that weighs about 2400 lb and got 17.5 mpg on the way up and 16 on the way back. I had two machines on the trailer on the way back that weighed about 1000 lbs together.
    I usually get 18 mpg driving to work except in the winter and it drops to about 16.5 with the extended warmups.
    1995 2500 HD 4x4 <br />6.5TD bored .030 over<br />18:1 compression<br />ported and polished heads and intake<br />3 angle valve job<br />homemade boost controller<br />12 psi boost<br /> <br />Leaves two 30 foot black marks on the pavement while taking off if you have a heavy foot
    Jul 2003
    Broadview, MT
    Before my engine went into self destruct mode I was averaging 14-15 in town and 16-17 on the highway/interstate, and I have a severe lead foot so I like to go about 80. The truck was totally stock with 410s.
    The best milage I got was a trip to Yellowstone were I got an astounding 26 mpg. All of this out of a bone stock truck. I have not even burned through two tanks yet on my new motor, and have been taking it pretty easy, so those numbers are still coming.
    Bbudus
    94' GMC K2500HD, Heath chip, -1.94, Turbo-Master, AFE Cold Air Intake, Bosch High Flow Injectors, 3" Exhaust all the way back, 4.5" chrome tip(exhaust sounds sweet), Heath Turbo Down Pipe, Heath Crossover, IssPro gauges, Three Pod Piller, 98' Cooling Mods, DMax Fan, High output water pump, DSG Oil Cooler, Heath PMD kit, Light kit with high output bulbs(very bright...finally)
    Mar 2004
    Reno, Nv
    In town I get 16 and usually 20-21 when road tripping. I hardly tow and when I did a long trip with a trailer it was 7-7500lbs and I waqs getting just under 16 but I was traveling about 60-65 max. Gears 3.42
    Phil
    2007 Metallic Blue GMC Crew Cab 2500HD LBZ Allison. 70K mi, 255/85r16 tires.
    1996 GMC 2Dr 4wd Yukon 190k mi, 3.42 rear end, 265/75r16 tires, 4l80e, 97 cooling mod, D-max fan blade, Hayden Severe duty fan clutch, Autometer Boost EGT Tranny temp, JK's 3.5 exhaust.
    Reno NV.
    sturgeon-phish Guest
    I just had my best mpg returning to work in Tennessee from Ohio. Mild temp, 60-62 mph, 323 miles, fill up run, fill up, (waiting for dissipation of foaming) 26.2. WOW. Previous mpg usually &gt;20 mpg, but I drive very easy, egg under the foot is my style.
    No one that I have read seems to take into consideration altitude when figuring mileage.
    For three weeks in May I traveled about 7,000 miles. Starting from Las Vegas, NV. to the east coast areas of Virginia, DC, Maryland, West Va. and Pennsylvania. I passed through Arizona, New Mex., Texas, Oklahoma, Ark., Tenn., going there, with a side trip to Dallas, and Missouri, Kansas, Colo. and Utah returning. I achieved between 18 and 23.5 mpg (US Gal.)Driving at about 65 MPH. Total average for the trip was 20 MPG. I observed that mileage above 1500 feet was significantly better than below. My best mileage was 23.5 MPG from Flagstaff, AZ to Grants, NM. This was all above 2000 feet in the mountains. As a check on how speed over 65 mph affected economy I drove 70 mph from the junction of I-70 and I-15 back to Las Vegas and achieved 18 mpg. This was all above 2000 feet and generally down hill. My town driving in Las Vegas varies between 15.5 and 17 mpg
    Altidude, speed and distances from my hand held GPS.
    94 Chevy TD Blazer, 4L80E Automatic Trans., 373 rear axel, Computer chip, Phaser Gears, Cooling upgrade, retrofited down pipe, Mr. Kennedy
    JohnC Guest
    Originally posted by cldowlen:
    ...I observed that mileage above 1500 feet was significantly better than below. My best mileage was 23.5 MPG from Flagstaff, AZ to Grants, NM. This was all above 2000 feet in the mountains...
    Hmmm, I find the idea that higher altitude contributes to mileage counter-intuitive. It seems to fly in the face of the "more boost is better" crowd, too. At altitude the turbo has to work that much harder to maintain a given manifold pressure.
    An aside, I live at about 1600' but burn an awful lot of fuel going up and down the hills to get anywhere... I have to go down 300' and up 100' just to get to my office, 3 miles from home. then it's down 100' and up 300' to get home...
    moondoggie Guest
    Good Day!
    [i]
