All right this problem is on my dad's 96 suburban,mods are K&N, 4inch exhaust, GM-8, complete cooling mod. Ok first a little back story, on a trip to Flordia while towing a ~3500lbs they averaged 16mpg over 2300 miles. About a month ago they made they same trip trailer wieght and all and they only averaged 11.5 mpg over the same 2300 miles. The only thing that changed was the adding of the high flow water pump and dual stats,truck had kennedy clutch with 9-blade fan for both trips. My first thought was to test for vacuum and boost, I put the gauge on the line that enters the wastegate, test drove it got nothing so bad vac pump, right. Now wanting to be sure of my self I take the boost gauge off my chevy put it on take a teast drive. What I found suggested a bad vac pump, only made 3lbs at wot, shut it off for around 5 min. When I start driving again I got boost ,8lbs spike 5lbs at cruise(65) and when I retested for vacuum I had 18 inchs. Just when I think I found the problem it does this to me. Anybody with any ideas thank you.
kris<br />email: kris985118@aol.com<br />1982 Chevy K10 325HP 6.5TD shortbed stepside 700R4, 208 tranfer, 4.56s, Rhino Lining, Exhuast By MUFFLEX 3inch, 6\" lift, dana 44 front, 14 bolt ff with gov-loc, 315-75-r16 Xterrains <br />there will be always future mods
