How I learned to live with the FSD\PMD, and love it.
This post is to cut thru the big words and techno babble, detailing simple instructions for repairing and re-using a failing FSD\PMD module.
Two distinct failure types occur -
1. Shuts off, no restart - this more than likely will require FSD replacement.
Try the procedure before replacement.
2. Shuts off, restarts
a. shuts off, immediate restart
b. shuts off, delayed warm restart
The procedure will likely recover this FSD failure.
I have over 2 years on a recovery repair made in late Summer '01.
Several DP members have reported recent repair success.
BETA, an engineer and DP member in Sweden, also attests to several long-term recovered repairs.
Refer to "IT'S 10pm - I'VE FOUND MY PMD" post by TODDMEISTER for FSD\PMD photos.
Remove the FSD module from the Inj Pump, or the remote FSD Cooler heatsink.
If the flexible thermal pad is stuck to the FSD, carefully remove it.
You will note two rounded parallelogram shaped wells in the aluminum side opposite the Stanadyne label.
The two transistor drivers are in these wells, under black plastic covers.
With a flat-blade screwdriver, carefully pry the black plastic cover off each transistor.
You will see two 1/4" nuts securing each transistor, one at each end
Loosen each nut, then run it down to the transistor case finger-tight.
Tighten each nut 1/2 to 3/4 turn from that point.
This will restore internal electrical connection, and thermal transfer.
Re-assemble the FSD module and thermal pad to the IP or Cooler heatsink, tightening each Torx mounting screw 1/2 to 3/4 turn past full contact with the plastic case.
Or, follow the instructions supplied with the Cooler.
A new htp insulating pad is available which prevents loss of thermal conductivity when FSD mounting screws loosen.
An article on this new htp is currently in the Member's Area.
Refer to "IT'S 10pm - I'VE FOUND MY PMD" by TODDMEISTER for photos of FSD\PMD.
Should you choose to attempt this repair, please note it in this post, along with success and\or failure.
Also note the vehicle year and model, and Stanadyne part number - 30214, 34264, 34583.
Mine is '89 GMC 3500 with transplanted '95 6.5TD, FSD #34583.
[ 12-05-2003, 08:38 AM: Message edited by: gmctd ]
