I was installing my new battery cables and discovered my starter was loose! The two long bolts were both loose and the case of the starter was also coming apart! I thought there was supposed to be another support bracket mounted to the starter? There is a stud on the end of the starter. Also there is a smaller bolt that goes thru the starter (maybe 2" long, kind of between the solenoid and starter) that had no nut on the other end and was just sitting in the hole? I don't know its purpose?
Can anyone let me know if there should be a support bracket and where it attaches too? This way I will know what to ask for from the dealer tomorrow, unless someone has some spart parts lying around
Thank goodness I didn't hit the key one morning and find this thing on the ground!
95 K2500 Suburban, 6.5TD, 150,000 miles, K&N, Bilsteins, H2 wheels (on the way), Isspro Guages (on backorder)
