I recently installed the Edge EZ to tow my 12K fifth wheel (actual loaded weight). I hope to reduce the amount of downshifting out of overdrive as I travel along the interstates. The Edge literature recommends that power level 1 be used unless you tow light. I have installed an EGT gauge and a boost gauge on my truck, but everything else is stock.
I made about a 20 mile trip with my unloaded trailer to check things out and was surprised at how quickly the EGT would climb to 1200 or 1250 on what I regarded as moderate inclines. I had T/H turned on, the cruise set for about 1900-2000 rpm, which was giving me about 63 mph. I tried power level 1, and the truck downshifted from overdrive on 2 moderate inclines. In power level 2, I did not experience any downshifts.
For those who have towed heavy using the Edge EZ or the Juice, what power level have you used and what has been your experience with EGTs? Will I be safe using level 2 so long as I keep an eye on the EGT, or would I be smarter to just put it on level 1 and accept what I can get?
Given the rapid increase in EGTs on piddling hills in Missouri, I am somewhat concerned about the 6% grade headed west out of Walsenburg, CO that seems to go on forever to get over La Veta Pass at a little over 10,000 feet.
2003 Duramax/Allison 3500 Silverado ext. cab 4x4; J&J Tubeless Tapered Running Boards, Retrax cover, Line-X
