Question for those who know..
In my taking apart the engine that came out of my recently acquired 82 diesel truck I discovered many many problems with the engine. One of which was a blown head gasket, and others include 3 broken plastic retainers on the rocker arms (later type).
Hmm, this ain't no 82 model engine, more like a 91 model (its weird in that it has a turbo oil feed plug in the front of the block where 6.5 turbo's get their oil) yet the block says in bold "6.2L Diesel" and is a 660 block not 599. Anyways, I also discoverd that someone installed 6.5 heads on this engine, the previous owner had supposedly "never got it running right" and had put heads on the engine (so I was told).
I know why it didn't run right now because of obvious loose injectors, bad wiring, poorly torqued head bolts (wasn't hard to remove em) and the junky later model rockers with the plastic retainers (better way???? NOT!)
So, I am going to try and put this engine back together (since it looks as though it'll actually run if I put it together right). I have never had this truck running, and am glad that I didn't try. Mainly because of the sludge I drained out of the oilpan (grey almost like light grease, smell = horrible). So I am assuming that it had antifreeze/water mixed in the oil from the heads. I didn't see any cracks in the bottom webs of the engine, I still need to take a closer look (usually water in oil = busted block right?).
First question, since I have the heads off I noticed rusting of a few cylinder walls (light, but they ain't shiny in a couple of cylinders). Should that be of conern, or will the rings bite again and clean em up? I really don't want to do a full rebuild now, as I will later with a set of 19:1 pistons (project in mind, saving 4 now).
Second question, I am thinking of putting on the 6.5 gaskets with the 6.5 heads, but I already have a set of 6.2 gaskets on hand and another set of 6.2 heads (82 heads though). Should 6.5 head gaskets be used on a 6.2 engine when using 6.5 heads? I believe that (according to crew84) that we should use 6.2 gaskets with 6.2 heads. So what is the consensus? Or would there be anything wrong with using the 6.2 gaskets with the 6.5 heads?
Thanks!
