Hey Guys,
Got a problem with the glow plug system and it has me stumped, that is not hard to do. At start attempt, no glow plug light and no start. Engine is turning over great, glow plug sensor and relay are fine, relay is cycling and I have battery voltage at the relay on the battery side (all the time). I R&R'd the Sensor and relay just to be sure, due to this happening before and the sensor was bad. I read continuity on the glow plug side to the frame, and I really don't know if I should. I have not checked the glow plugs because the wiring diagram indicates that the light should work even if the plugs don't. I also notice a fusible link in the diagram, but I am not sure if this is blown, on both sides, that it will effect the light function. HELP!
