my 82 sub with a banks on it on startup smokes like wildfire on startup white smoke but after say 20 seconds or so clears up and you never see anymore smoke black white or other and come below 30 degrees forget starting it it won't go and i've noticed since i put a banks on my 84 1/2 ton that it acts the same way, before i put the turbo on it would start down to -30 degrees after being plugged in for about 2 hours now i can leave it plugged in all nite and i'll be lucky if it starts. is this something turning the pump up will cure?and if so how much.by the way it is firing on all cyls allglowplugs are working.
