Hello
After going through a problem with an out of control engine due to an IP problem i noticed that my pump was adjusted so that it set directly on the on the static timing mark. Having had a cooling problem since i got the engine from Peninsular i have been on the look out for reasons that it would be running hot when i noticed where the timing mark was in relation to where at had been on previous engines the first thin that came to mind in that the engine had never been timed since the pump was put on. so would this lack on timing by my friends at Peninsular be a possible cause for running hot?
1989 Chevy Suburban peninsular 6.5 turbo.
