I had my starter off the other day (was not cranking well), and in my rush to remove it I did not pay enough attention to which wires were connected to which terminals.
The battery cable from the passenger's side battery clearly connects to the fat terminal on the solenoid. The remaining two wires (much smaller conductors) are red and purple. One of them (I can't remember what colour) has a larger diameter connector on it than does the other... does this also connect to the fat terminal on the solenoid ? The wire with the smaller diameter connector would then connect to the ignition terminal on the solenoid ?
BTW, my solenoid has three terminals, the fat one, the ignition one (small diameter terminal, labelled "I"), and another small diameter terminal (labelled "M"). What is the "M" terminal for ? This is not the orignal starter, but a re-build.
Thanks.
Rob
