Hello All
I am in the process of installing a Diesel Depot 325 HP engine in my truck. Since the truck has a six inch lift I pulled the radiator support and the pass. fender to make it easier. When I pulled the radiator I noticed that it was very corroded and the old coolant had oil mixed in. So a new one is needed. Finding a new has been harder then I thought, I have tried Napa, but the one they got for me fit the support but was only two core (four core is needed) plus it didn't have both trans and oil coolers. I will be putting aux. coolers in but every little bit helps. My question is were are you guys getting a new radiator from, is there anything better then stock available? Stock would be fine as I have the '97 cooling upgrades and the Kennedy clutch with 9-blade steel fan (I switched to serpentine accessories). thanks in advance.
On a side note my engine has the GM8 turbo on the factory style manifold, if you plan on using this setup in your truck and you have a/c you will most likely have to remove the a/c in order to install the turbo. I personally am switching over to the Vintage Air under dash setup, it is not an easy conversion as you must fabricate your own mounting brackets and lose most if not all of your glove-compartment. I can go into more detail on this once I have finished installing it.
ely have to remove the a/c in order to install the turbo. I personally am switching over to the Vintage Air under dash setup, it is not an easy conversion as you must fabercate your own mounting brackects and lose most if not all of your glove-compartment. I can go into more detail on this once I have finished installing it.
kris<br />email: kris985118@aol.com<br />1982 Chevy K10 325HP 6.5TD shortbed stepside 700R4, 208 tranfer, 4.56s, Rhino Lining, Exhuast By MUFFLEX 3inch, 6\" lift, dana 44 front, 14 bolt ff with gov-loc, 315-75-r16 Xterrains <br />there will be always future mods
