My question deals with a statement made in gmctd's post in another thread about the changes made to the 6.5 IP's: "Throttle guide stud is externally adjustable for governor tip-in". As I recall there is a spring in the stud assembly and an adjustable nut on the back of the IP housing through which the stud is screwed. How do you set the adjustment on this stud and what does it affect in terms of pump performance and operation. What is governor tip-in? Thanks for the info.
Randy
2006 GMC 2500HD Duramax Allison Crew
